Having alcohol injection you should not need to spray your IC.
Perfect example is the WRX that comes with an IC sprayer. There are plenty of fast ones that show zero gain spraying on the IC.
Your performance increase may have been from different temps when the car was run.
Put it like this, you cool the car for an hour. Do a run. Cool the car for an hour..do a run with the spray on the IC.. you wont see any gain.
The hotter the air hits the alky, the better it flashes..so even if you were spraying, and the temps were to have come down.. it would of been counterproductive.
Time for you to redo your track tests. 5 without spray. Zero changes, temps monitored for coolant to assure they are the same. And easy launches to assure the numbers dont get skewed. Then 5 runs with spray on.. and all 5 of the spray runs should give you a 2 mph increase under same conditions. If you get the mph increase on the 5 runs, next run without... and the mph should come down. No changes to FP, boost, air in tires, nothing.
This is how I test new things on my car.. its the only scientific way I know how to. A few runs.. isnt ever enough.
If it does work this way, put your timeslips up showing before and after runs.. and this will sway us non-believers that it works.
