Finally got back to the track after a year of picking at the car and an embarassing 10.5@69mph last year. Turns out cam was wiped, 02 sensor and Maf were way off. Everything perked up with the new 202/202 cam. Anyways, went back running 18lbs of boost on pump gas with my thrasher 92 and 0deg of knock. 02's ranged from 830 to 770 when the sun went down. Got a 9.3@74mph and a 9.4@75mph and 2.1-2.3 peglegged 60ft times. My question now is where to go from here. Would a a higher timing chip like my kennebell 93 chip be a better strip chip with less boost, or is the thrasher at 18lbs the way to go? I'd like to stick to 93octane until i get dialed in. I tried lowering the fuel pressure from 43lbs line off to 41lbs with no real change. I know a good rear would lower my et via a good launch but what should i do to get more power?
