excobraguy
- Feb 25, 2007
So I recently purchased one of TURBO89's spring compression tool to install my new springs. I sent him a pic of the Kirban design and asked if it was like the Kirban design, he replied it was similar but the newer "updated" design.
Now I get it if some of you reading this bought one from him and it worked fine (all welds are different), mine however did not and I will show why and I am very displeased with his response when I asked him about it.
So the one I bought had two welds holding a single nut on the back of the rocker. The bottom weld was just globbed on and prevented the wrench from making contact with enough of the nut to put any kind of torque on it to compress the spring, thus the wrench would slip off. I almost lost an eye when one of my keepers popped up because of the wrench slipping off.
The 2 design flaws I pointed out to him were the fact that the weld prevented the wrench from going all the way on and also, unlike the Kirban design, he welded the nut too close towards the shaft on the rocker. When you actually turn the wrench it comes into contact with the bolt head holding the shaft portion of the tool.
So when I sent him this information of course he blamed me saying I wasn't doing it right and everyone else was using an "offset" wrench with this tool. Ridiculous.
So below are the pics of his welds and me showing how the tool comes into contact with the bolt on the shaft. Now keep in mind, with the weld glob, only one useable position worked on the tool. And then that one didn't work because I would hit the bolt holding the shaft portion of the tool.
So I cut it part and removed his nut and built my own this morning.......TURBO89, mine works great!
My suggestion if you buy one of these from him, be prepared to modify it......
