83TurboGuy
Whynd it up
- May 11, 2010
How do u build up pounds on the turbo when u hold the break and gas nothing really happens when i do it wheels just start spinning ??? What the right way of doing it
If you're trying to do it on 22's then the tires will do nothing but spin. They don't work the right way for performance. Get some 15's to 17's and you might get some traction out of the car. By putting very over sized tires on it you've changed the position of the instant center and the axle is out of alignment with the rest of the running gear so it just spins the tires.
Sounds like it's working to me. What else would you want it to do? It's not going to launch off the e brake.
Also make sure your rear brakes are in good condition and the self adjusters are working properly. You may want to take the drums off and make sure they're adjusted real good. You should be able to turn the drum with just a hair of resistance from the brakes. Also scuff the inside surface of the drums with some 60-80 grit sandpaper and remove the shiny surface so the shoes can really grab hold.
The reason the tires are spinning is because everything is doing the right thing. The engine is making enough torque to spin the tires and the tires don't have enough traction to hold the surface of the pavement. You need some sticky tires and a few mods to allow the car to accellerate instead of spin.
If you're refering to the guage in the dash don't rely on it, get a manual guage so you can see how much pressure you really are running. Here's a site you need to go to and start reading.
BEFORE BLACK Website
The fact that you're blowing the hides off the tires is proof that you're building boost, unless you've got a really strong engine.
i got another problem i got low oil pressure i have a high flow oil pump u think that might effect it ??
o i c so the car can build up boost and lanch right ? couse that other guy said it doesent....
