Chris Taylor
Got 6?
- Aug 14, 2002
I have a Level 10 transmission that worked great until I changed the fluid and filter. I know that sounds crazy but thats when the problem started. This trans. was working great, 1-2 shift was very firm and positive along with third and O/D. I was tuning on the SMC alky. and was going to mash from a low first gear roll, full throttle. Started pulling like mad and then glided into second. I had this sickening feeling in my stomach and knew right away what had happened. Thought I would try seeing how the second gear band would hold by dropping out of third. It slipped second and slipped going into third. O/D still applies OK.
This transmission has less than 4,000 miles on it. Under normal driving the trans. works great. Good firm shifts through all four gears.
Could changing the filter and fluid do this? I guess I will put new clutches, steels and a band in it. Any ideas? This sucks
Thanks,
CT
Thanks,
CT
