hemi8
Goin Sideways
- Jun 6, 2001
I've tried quite a few brands and the Hurst and B&M products still do not have it right. A bracket which the aftermarket cable connects to on the side of the 2004R (the part that moves as you go through the gears). The current design will not allow the shifter to go into all gears manually,perfectly. Either you get 1st gear or park, the geometry is off just enough to not allow both. The angles are to intense all the way forward to all the way back. I welded and modified my original bracket to the Hurst bracket to get it to work but someone with a lift could design a proper bracket to sell to the masses.
Mike
86 GN
Mike
86 GN
