highboostgn
- May 24, 2011
Im thinking its running super rich on the top end...But then again wouldnt that cause the knock gauge to light up?With all that has happened wishing good luck.your way w the popping noise.. nice run imagine if 60' was lower. Prob close to.mid 11s
i think it was from 92-119It could have been a lean misfire, hitting rev limiter, floating valves, etc. usually an over rich mixture won't misfire that bad at full power. Richer mixtures are easier to fire than lean ones. I've seen some high hp nitrous engines hurt by over fueling but they were making over 150hp per hole. Not typical on 70hp per hole engine no matter how rich you get it. It will just lay out a lot unburned fuel and carbon monoxide. You have the mph of an 11.1 car. What was the eighth to quarter mph pick up?
What do you mean by linearIt tells you that the boost wasn't even close to linear across the pass if he didn't let out at any point. Though wheelspin will increase it also. My car picks up 28.5mph out the back on a 140mph pass
I gotcha. Well hopefully I'll get the ET streets to hook. Having stock suspension probably isn't helping and will be my next upgradeHe means the boost spiked up or down.... Or you let out.
I think your spot on with wheel spin in the 1.9-2.0 60ft and MPH. Thats a low 11 car.
You loose ET and gain MPH when spinning out of the hole because you loose momentum. At a certain point, like 1.9-2.0 60ft it starts to hurt MPH and ET because so much forward momentum is lost.
That's funny. I had mine set right at 20. I ll try 16 next time. How much boost did you leave onTire pressure is key with M/T drag radials. I had a similar experience as you last year. I read all these posts that said 18-20 psi at the track.....NOT! result was 1.9-2.0 60ft 92mph 1/8 and let out . Next time out, 16psi netted me 1.54 60ft and 95mph in the 1/8.
