Details of the run:
60' 2.000
330' 5.620
1/8 8.589
MPH 82.50
1000' 11.125
1/4 13.239
MPH 107.02
EMPTY WEIGHT:
BLOCK: Stock 109
HEADS: Stock
CAM: Stock
TRANSMISSION: Stock (3/4 the way dead though )
TORQUE CONVERTER: Stock
DIFFERENTIAL: Stock
INTERCOOLER: Stock
THROTTLE BODY: Stock
RJC POWER PLATE: Yes
INJECTORS: 009
THERMOSTAT: 160
TURBOCHARGER: PT 61
VALVE SPRINGS: Unknown but think Stock
MAF: LS1
DOWN PIPE: ATR
EXHAUST: ATR
FUEL PUMP: Hotwired Walbro 340
FUEL PRESSURE REGULATOR: ATR
FUEL PRESSURE: Unknown
ALCHOHOL INJECTION: None (But soon)
PROPAIN INJECTION: None
NITROUS: None
AIR FILTER AND AIR INTAKE: K&N - Aftermarket 3 inch chrome
TIRE DESIGN, SIZE & AIR PRESSURE: Original stock
AIR BAG(s): None
SUSPENSION: Bilstein HD
SCAN TOOL: Scanmaster 2.1
FUEL: 116
CHIP: ATR street chip - from 1992
CHIP TIMING: Unknown
KNOCK RETARD: Alot between shifts (Thanks trans) Around 19
OXYGEN SENSOR VOLTAGE: 789
EXHAUST GAS TEMPERATURE: Unknown
TRACK ELEVATION:
TEMPERATURE: Cold!
PEAK BOOST: 22
BOOST AT LAUNCH: 0
MILES ON THE CAR/ENGINE: 20k
Well all in all I was pretty happy with how it went. I thought it would be alot worse since my trans is none too happy and I could definetly use a new chip and converter.
My other run came out to 13.575 @ 106.73 and a 2.4 60 foot. And I was going 179.71 in the 1/8th, the slip says so I can prove it!
My next mods were going to be rebuilt trans, 3k stall, 60 lb injectors, new chip, alcohol injection. Hopefully i'm heading in the right direction. Any other suggestions greatly appreciated. I'm as new as they come to turbo Buicks.
60' 2.000
330' 5.620
1/8 8.589
MPH 82.50
1000' 11.125
1/4 13.239
MPH 107.02
EMPTY WEIGHT:
BLOCK: Stock 109
HEADS: Stock
CAM: Stock
DIFFERENTIAL: Stock
INTERCOOLER: Stock
INJECTORS: 009
THERMOSTAT: 160
TURBOCHARGER: PT 61
MAF: LS1
DOWN PIPE: ATR
EXHAUST: ATR
NITROUS: None
AIR BAG(s): None
FUEL: 116
TRACK ELEVATION:
TEMPERATURE: Cold!
PEAK BOOST: 22
BOOST AT LAUNCH: 0
