BlackBandit
God loves Buicks!
- Mar 29, 2003
180 at highway speeds in 75* weather is not good imo. Yes as mike stated the car might run well at that temp, but outside temp and coolant temp are pretty linear. If you are running 180 in 75* heat its gonna run 200 in 95* heat. and 210-220 with the AC on just like my car was with that same aluminum radiator. 180 in 75* heat is in no way a testament to the radiator. My car was 177-180 yesterday in 100* heat with my 4 row stocker that I had to reinstall after the disappointment of the aluminum unit. I got on it 3-4 times and it went to 190ish and then came back down to 178ish. With the aluminum radiator ya'll sell I was seeing 195-205 just cruising. If I got on it, it couldnt get rid of the heat, even after 5-10 mins of just cruising.
Coolant temps should NOT be linear. If you have a 180* t-stat you should be at 180* whether it's 30* out or 90* out. Anytime you're coolant starts to go above your t-stat temp you're exceeding the capabilities of your cooling system. That's just the way it is. Now, many people are ok with that because it isn't a neccessity to have a cooling system that's capable of dissipating all the energy all the time. It just needs to be able to control and recover. (like when the temp climbs during a run and then comes back down) If you're at a point where your coolant is all ready higher than your t-stat during normal conditions though you're asking for problems durring more extreme conditions. This is evidenced by coolant temps rising with ambient temps. I guess what I'm saying is that while there are many opinions about what's acceptable the above are facts and my opinion is that your cooling system should be able to maintain your t-stat temp during whatever your normal conditions are so that when you have an extreme condition it isn't as likely to be completely inadequate.
One last thing that is important to note is that the radiator is only part of the cooling system. Everything from airflow over the raditor and engine, water pump, hose routing, coolant type, and more makes up the cooling system. Enhancing any one part of the system will yield some improvement in system performance but finding the weak link and working on that will yeild the best results.
