torque convertor bolt thread size and how long are they
regalwe4
i just bought a used billet pts extreme torque convertor it is a nine eleven convertor ,does anybody know torque convertor bolt thread size and how long of a bolt i need ,the convertor came with no torque convertor bolts.
thanks regalwe4 Kevin
you will want to get a grade 8.8 at the very least this is comparable to our grade 5 sae, A 10.9 0r 12,6 would be best for strength auto zone sells a set in their help section that will work. HTH mannie
If you know what lenghth you need I can mail you a set just measure the stuff up in mm . we can covert it if you use inches. let me know we can help you out, Mannie
I used the ones from the help section at advance auto . Worked out well .
The ones that Mannie has might be better as far as strength and quality .
