Let me ask you for a professional opinion, Chris. If you had just made your 8.9 run, and after the run, through your datalog, you found that you had just run an 8.9 with the a/f ratio bouncing off of 14.64:1 or leaner due to a fuel system malfunction you would later track down, do you think that maybe you could end up improving on that 8.9 run after having fixed the fuel system problem, and by doing that, getting the a/f mixture where it really needed to be?
Would you end up going even faster than that previous 8.9 run?
