Thinking about selling S2 drivetrain
NOT FAST
Motor was built by Performance racing engines in plainfield Il.
4.1 S2 block is off/c, 016
4 steel mains (center 2 4-bolt),
wetsump-style (currently tapped & plugged)
lifter bores drilled/tapped/plugged
Bored/TP honed to 3.980
Squared/decked —9.540
Piston oil squirters installed
Crank is BMS forging, narrow journal, 3.400, 0\0 rods/mains (magged 3x/checked/polished)
Rods are new Carrillo 6.5, .990 pin, .850 wide, .100 offset, latest bolts
Pins are Ross tapered PBR-style, 2.750”
Pistons are new Ross 9.0:1, -34cc, dual spirolox, slight flycut, .004 clearance
Rings are new TotalSeal (not zero-gap), 1/16-1/16/3-16, .018 top, .016 2nd (moly, cast)
Main bearings are new BMS, 2.5 clearance
Rod bearings are new Clevite 2.1 to 2.3 clearance
Rotating assembly balanced full internal
Cam is new Reed hyd roller 232/232, .560/.560, 110 l/c, 270 adv
Lifters are Speed Pro hyd rollers,
Rollmaster timing chain
Heads are alum S2, 2.02 SS intake, 1.60 inconel exhaust, med porting, surfaced, multi-angle valve job, new Isky springs,“M” (med lift) T&D style.
Also will Include
160 lb injectors
sheet metal intake
stainless twin turbo headers
two teil wastegates
dry sump system
mezere electric water pump
th400 trans with BOP ultra bell
and the list goes on, cant think of it all right now.
I have a solid 40k wrapped up in all this ****. Everything is brand new/never run with the exception of the dry sump. $27,000 takes every part I have for this thing. I dont need to sell it so the price is pretty firm.
Any chance on parting any of those "also included" pieces out? Who makes the dry sump?
If I dont sell everything at once, Im just gonna put it togeather this winter. Im at the point right now where I would just assume sell it all and put a big down payment on a new viper :rolleyes:
Also have hipster 5000 stall converter
tiel blow off valve
and the headers are atr forward facing
i knew this name sounds familiar....
this sat...same time same place.
And you sir are the only one. Lets keep it that way;) Might be out maybe not hit me up on my cell saturday night.
Someone buy this **** off me so I dont have to bug Dr Boost all winter for help
