87buickracer
- Dec 2, 2004
Get a TH 350 pump bearing and pump bearing shims in .010,.015.020.
Knock the case bushing up slightly so the pump bearing and pump shim have something to pilot off of.
Remove and discard the 3 tab case washer and the 4 tab TW on the output shaft.
Usually the .015 shim sets the endplay right where it needs to be.
The pump shim and bearing go down where the 3 tab washer use to be.
Now you have rollerized the output shaft.
(This is just my opinion, Flame suit is on)
I would suggest leaving the intermediate snap ring where it is in the pix. The reason why:: If you put the openings of the snap ring opposite of the intermediate band anchor lug, you effectly turn the snap ring into 2 half moon shapes that don't have the lug engagement compared to the way you have it. (tomato/tamato)
This is for OTTO: The snap ring in the pix is a Torqueflight 8 rear clutch snap ring in either .088 or .106 variation. They are easier to source.
Whatever you do ,and this will sound totally stuipd and counter productive; Run a wave steel in the intermediate clutch pack. It will be easier on the snap ring, pressure plate,and case lugs and will have no ill effect on the durability of the clutch pack.
Mike.
thanks have the wave plate on the intermediate pack..
like the idea of the rollerized output shaft.
