TBITT, That is where we install one as well.All forces in the 400 try to push the geartrain out of the back of the case .Supporting of the direct drum up front takes it out of the rear thrust equation and frees up horsepower in 1st and 3rd gears.
The only thing trying to push the front unit (forward and direct clutch drums) rearward, other than G forces of acceleration, is
lube circuit pressure. The thrust from G forces is manageable. The rearward thrust of the front unit is already supported by needle thrust bearings. That would be the sun gear to rear ring gear, and the rear ring gear to output shaft needle thrust bearings. The stock case thrust washer would be the only spot that would be causing hp loss from excessive friction. That spot has already been addressed by transmission builders decades ago. That would be the TH350 pump needle thrust bearing put in place of the OEM thrust washer setup. Old news.
Now, let's look at something very important.
This is breaking news, first presented here, so read up. In the above paragragh I highlighted lube circuit pressure. How many of you have already figured out what might cause excessive rear thrust load in a 400? Enough to wipe out the OEM case thrust washer arrangement. The same way that the engine crankshaft thrust bearing can be taken out by excessive torque converter fill pressure.
Excessive torque converter fill pressure translates to excessive crankshaft forward push, which translate to short crankshaft thrust bearing life. Excessive torque converter fill pressure also translates to higher cooler line pressure (cooler line flow feeds the lube circuit upon return to the transmission case), which translates to excessive lube circuit pressure, which translates to excessive rearward push of the front unit in the transmission and excessive loading on two needle thrust bearings and one case thrust washer.
Are you guys seeing the picture yet? If you really want to free up
horsepower and make your engine and transmission more durable, address the torque converter feed pressure in the T/C. If you're wiping out needle bearings in your transmission and feel you have to add more thrust bearing locations, your lube circuit pressure is too high and/or endplays are too loose or too tight.
This brings us back to the cause and effect that I've been preaching to you guys for years now. You must restrict the torque converter feed passage in the pump cover. It solves a multitude of problems and
frees up horsepower.
Maybe now that everyone realizes that the pump mod can
free up horsepower will make everyone jump on the bandwagon and do the mod. I'll bet people will be shooting for even less than 40 psi cooler line pressures now. Ha ha. :tongue:
Remember, the important spec when it comes to cooler lines is a flow of
one quart in 20 seconds. I've even played with restricting cooler line pressure to
zero and still had
one quart in twenty seconds of flow.
