Into the racing plugs for those: AR3933
Non-projected tip, cut back ground, although they are a non-resistor plug. Not sure if that would be an issue or not. There are also plugs for one & two heat ranges colder in that style (AR3932, AR3931).
There is the 403 spark plug (and 402, one range colder). These are flat gasket seat, 3/4" reach, resistor, non-projected, with a 13/16" hex for the wrench. Should be enough room for the larger hex, but would eye-ball it first.
In that same 13/16" hex is the 4063 & 4062, these are also colder then the 403 and have a necked down center electrode. Used in some performance cars (porsche, lamborghini) and a bunch of watercraft and motorcycles.
RemoveBeforeFlight
