Eric Stage I
TurboTweak Guy
- May 25, 2001
Hi Guys,
I already posted this on the SyTy board, but I'll copy it here too.
At long last, the Scanmaster is finally here! I have them in stock now.
Features
Data Monitoring
-Monitor ECM and sensor data in real time.
Code Clear
-Clear malfunction codes from the ECM’s memory.
Serial output
-Log data to a laptop PC using TunerPro through a serial port on the back of the unit. Serial cable is included (USB adapter may be required.) We have written a special ADX definition file so TunerPro reads the Scanmaster correctly.
Peak Capture
-At full throttle, the peak knock retard and leanest O2 values are saved, along with the respective vehicle speeds.
Analog inputs
-A 3.5mm jack for connecting two 0-5 volt external signals, which can be datalogged to a laptop. You can connect a wideband 0-5v output directly to the Scanmaster if you want, to display on the screen. It will also insert the wideband reading into the datastream to display on TunerPro. This is not required if you already have a wideband wired to your ECM with a "patched" chip. You can do it either way.
This will work with the stock chip, or any chip that uses the stock datastream including my Velosyty chip. Should work fine with code 59 users. You can configure it for a 3-bar MAP.
Here's a link to the instructions for details:
http://www.turbotweak.com/scanmaster3instructions.pdf
Normal price is $269, but I'm going to do an intro price of $249 until the end of January
Features
Data Monitoring
Code Clear
Serial output
Peak Capture
Analog inputs
