perhaps this has been addressed and i will do a search but would like to hear some comment:
since our systems (mine is Alkycontrol) are generally manifold pressure actuated it would seem that between shifts and into the beginning of the next gear they could run lean while the system catches up. i have not experienced this but have only been doing 3rd gear pulls and tuning so far.
offsetting the boost drop might be pump momentum run-on... if it exists???
here is a typical question (from an EVO board) on the subject:
EVO forum
i have a progressive kit and i can tune(AEM) it in 4th gear and make the afr's hold very consistent, but when i do a pull in 1st, 2nd or 3rd the afrs are all wacked. it usually goes lean for about a second(14-15afr) coming into boost. kinda seems the pump isn't keeping up the volume when the engine accelerates faster in the low gears. is there anything i can do? I'm about to use an on/off setup. is there an accel enrichment that might work? thanks everyone.
here is a reply from an Aquamist engineer:
I don't think you are going to be able to solve your afr problem that easily.
If your progressive system is manifold pressure driven and made no reference to RPM and Gear position, you won't be able to get a consistant afr in all gears.
Assuming you have all the above inputs, if the AI pump speed is not responding fast enough to your load change, you will always have a afr gap.
I suggest tuning your progressive kit over-rich at 4th gear and hope the lean condition disappears at 1st, 2nd, 3rd gear pull.
I have mentioned this problem tuning a progressive system before on this forum
and I suggested the a fix delivery rate (on/off) system gave less tuning problems.
This is just my opinion of your present situation and I am not bashing the concept of a progressive kits against an on/off system. Please do not take it as such.
i would be delighted to hear comment.
thanks,
howard coleman
EVO forum
thanks,
howard coleman
