- Nov 24, 2001
anyone here done this combo change? what did you gain with no other changes?
here is the cars combo when it had the pte44-
should i expect the car to gain any power?? lol
the 87 limited has never had the motor pulled, heads off, or front cover off-
thdp,hooker cat back with hooker turbo mufflers, pte44, hard MAF pipe, stock MAF with no screens, BGC 23 row stretch, had a hemco, replaced with RJC power plate, port matched intake, 62mm t-body, msd 50s with reds 107 race chip, bruce's 9-11 convertor, pmac trans, 979 valve springs, and thats about it-
the car was running thru the muffs consistantly 11.35- 11.40's at 118-119.7 with 28 psi of boost~ or a lil more
she never knocked, and ran great- on scanmaster-
so- now that i have a scm alky kit, egt, tach, boost controller, directscan,power plate, and the 54 turbo. i think i will be able to squeeze another 3-4 tenths out of this car all loaded up with race gas and race chip- and no alky-- unless it knocks, then i will turn it on instead of popping the original head gaskets
i just checked my PTE and it lists the h.p. rate for the pte54 as TBD grrrr-- now i cant figure out the cfm flow
sorry for the long post- but what times is anyone else seeing with my combo?? i have a set of o-ringed heads ready to bolt on, but want to see the actual h.p. gains over the pte44??
my guess is that this 54 will make the same power as the 44 did, but hopefully at 4 or 5 psi less boost
thanks for the responses
bryan
bryan
