blackdeathtrap
smoking six barrel
- Apr 1, 2010
heres my current set up where should i go next to get biggest gain im in no rush so lost of time for discusion
i have 87 gn t top.
solid body new stainless t top frames.
oil press water temp volt boost and casper knock gauge scan master and tac with shift light fuel pressur gauge on the hood.
tt street chip il double check but its 16 to 18 psi with 18 degres of timing , billet fuel press reg adj , 3 dp 3 inch duel exhaust magnaflow (sounds gorguse),race tronix hot wire kit, walbro 340 pump, new fuel tank, stainless fuel lines, 4 inch tin man intake, 3.5 inch zr1 maf, translator,3 inch maf pipe, mild port and polish heads and intake manifold,by pass tb coolant line, stock turbo, stock ic eibach 1.5 in lowering springs mickey thompson street et radials 275 50 15 on 8.5 american racing outlaw 1 wheels 215 70 14 le radial turbo actions up front tubular upper control arms gutted front bumper. i run bfg radial tas on stock rims 235 60 15 and 215s in the front mostly on the street because dont like paying 270 a tires every season for new et street radials.
what should i expect with all these mods sieng i havent gotten to drive it since it was basicaly bone stock.
dos any one have aprox same mods so i can get an idee what il run et wise and how much power will this give me.i wanna know i just cant wait till next week end to drive it
what should be next bigger injectors more boost
bigger turbo
better inter cooler
or go to the dark side and get alky razor kit and turn boost up
or is there some other small things such as egr delete and some other things that would be cheap hp
i have 87 gn t top.
bigger turbo
better inter cooler
