Installed mine yesterday. Simple installation with Racetronix intank wiring kit(well worth the 35 bucks). Used a dremel to trim the sending arm shaft and cut the lower ring mount about 1/3 open (the thin part is gone) to set the sock down where the original was. Two 2-1/2" stainless hose clamps the hold the pump to the sending unit. You need 1 M4(4mm) and 1 M5(5mm) stainless nuts with lockwashers for the wire terminals on the pump. Position the sock to the side of the float which is almost a natural position with the ring mount cut. Unit slide right in tank a little tight but easy.
