This is kinda hard to explain but Im gonna give it a shot. Alright, so at WOT my TR is losing power. This is an intermident problem I have been having over the last two weeks. During hard acceleration thru first gear things are normal...shift into 2nd and as the car gets in to boost, around 8 lbs, the car seems like its hitting a rev limiter of some sorts. The car will buck with power then lose power then power will come back. Weird Huh? Ive checked for boost leaks but everything is tight and snug.
I had MAF sensor issue about a month ago but its has been replaced. All be it with an Autozone MAF but the car is not throwing that code anymore. I do have an EGR code that popped up as well. I reset the computer to clear the code but the loss of power problem is still occuring. I dont get paid until the end of the week so I will replace the EGR valve then and pray that is the issue.
