counterman
- Dec 28, 2006
I just reinstalled my freshly rebuilt 200 od in my GN, and, of course, I am having trouble. I had it done by a local tech who has a good reputation, and does hp stuff, too. In any case, I have good reverse and first gears--no problem. Shifting from park or neutral to either drive or reverse is firm with no indication of trouble. However, on my slow shakedown cruise around my neighborhood, I discovered that the trans will shift from 1 to 2 on its own, as usual. However, it obviously slips heavily in 2nd, and nearly free wheels if given throttle. I did not mash down on it, obviously, as I was just making the block around the street. I don't want to roast this thing, so I just put it back in my shed. I readjusted my tv cable, and it clicks 2-3 ribs in from the end each time. No problem there. The trans behaves the same. Before I run this thing up on my trailer and bring the whole car to the shop, what are your opinions? Could it be a stuck tv in the valve body? Thanks in advance. Counterman.
