Stomp! Crack!!!!
DorianL
Oops!!!!!
Hey all. I just had my car towed. Running a blown 400 SBChevy with 600ft/lbs and 620HP.
I rebuilt the trans with some goodies: hi pressure regulator, wide band + anchor, billet servo, billet anchor, shift kit, hardened stator, rollerized center support, D5, properly celaranced.
I am going 60 mph annoying a Porsche, stomp gas in third and shoot off. Shift in fourth and I hear... well I'm not sure - crack or backfire from rev limiter. All I know is that the trans let's go. No R and no FW. Just a whirring sound.
I shut down eveything and had it towed.
I am about to drop the trans but... kinda before hand... any clue what it could be?
Not that it really matters that much since I am 90% sure I'll have to drop the trans to find out.
I do not ahve a hardened input shaft.
Cheers
D.
x2 on the forward drum shaft.
That part needs to be a billet part to handle the kind of power you're making.
Since it happened going into 4th im goign to say stripped splines on the OD carrier. You cant run non/under accumulated oil to 4th since it will shock the carrier and crack it or break off the input.
CK has the Billet Forward Drum & O/D Ring Gear on sale, not the O/D Carrier or Input Shaft tho.' Sounds like he needs a package deal with that kind of power.
Hmmm, wiggling the low reverse clutch pack through the case... there is a LOT of play...
Planetary
