Mr86t-type
- Feb 25, 2007
Guys,
A few quick tuning questions, I finally made it to the track the other day for some tuning, and I feel the car is really running Great, my Combo:
Razors Alch kit(with Meth), Bone Stock Turbo, Stock Intercooler(with screen), Stock Injectors, Walbro Pump w/wiring upgrade, Power plate, Test pipe through 2-1/2" SS Dual exhaust. Of Course Mint 11,000orig mile car that was NEVER raced before I bought it 1.5 years ago
(Not guessing on that either, I know it for a Fact((but thats another Interesting Story))had 5 passes..turns out I pretty much had my car dialed in from my street tuning,
Weather was '60 degrees with Medium Humidity,
I was running ~22Lbs., with the Alch at the factory 5.5 setting and 93 Octane, No to VERY Little (1.2degree in one or two frames) knock, and Extremely Consistent 12.9s @ between 107.5-107.99, I had Erics chip at 24/23.5timing..now I know I could have turned DOWN the timing and ran higher Boost, but I 'Think' that might have slowed me down, as the factory turbo supposedly LIKES Timing..oh and SOFT 0-1Lb. launches (2.0060ft), on my 245 nittos (No need to Impress the EMPTY bleachers)..here are two of the five passes, the other three are Almost identical:
1. 2.052 60'
5.500 330'
8.361@86.16 1/8th
10.830 1000
12.913@107.99 1/4
2. 2.110 60'
5.504 330'
8.351@86.36 1/8th
10.818 1000
12.906@107.91 1/4
O2's started out at ~850 and slowly decreased to ~770 on VERY the Last Frame(typical for all five passes) of course 255 on the mass Air..
Now I Tried Upping the Boost to 23-24Lbs but had to quit due to KNOCK Counts coming on, ~3-4 degrees of retard, so I turned it back down.
So now the question being: "I thought the Stock Turbo ran Best with High timing, so should I LOWER the timing and Increase the boost??" and
"In order to Increse the Boost at the same timing, would Upping the Octane (little race gas mixed in) help with the Meth??"
1. 2.052 60'
5.500 330'
8.361@86.16 1/8th
10.830 1000
12.913@107.99 1/4
2. 2.110 60'
5.504 330'
8.351@86.36 1/8th
10.818 1000
12.906@107.91 1/4
