TurboTdr3.8
- Jan 15, 2013
At this point need to try a Coil and module .There's no spark reaching plugs,
i think i solved that issue my car would turn over but wouldn't start it would sometimes fire and the fuel pump sounds really quiet couldn't hear it come on found out it was the ignition swtch on the steering column
Did you check the 3 fused power wires connected to the starter. My lug was loose and the car would die for no reason and very sporadically it seemed until I found it. You may have already been there but I just feel for you and that's the only personal experience I've had with that issue.
The car didn't act up until 10+ psi of boost was built, otherwise it didn't miss or start bucking so i was avoiding building boost near that level so i wouldn't hurt anything on the way to the parts store. The day before i had the starter replaced it got alot worse with bucking at less level of boost; so i had her towed to a shop that replaced the starter free of charge under warranty the next day because the bendix went south the night before, as i was on my way to oreilly's when it stalled at a light & after 4 times of refiring then stalling again the starter quit on me. It ran ok after the starter was replaced that day then it had started missing again on the way from the shop to the oreilly's where she has been since.
I have had this EXACT same scenario ... on a customers car ... Spent about an hour trying to figure it out ... was a bit tricky ...
Here is what I found .. the connector by the Cam sensor --- one of the wires was broke and had intermittent contact ... depending on how it was angled and
how it was stressed sometimes the car would run sometimes not ...
CHECK THESE WIRES CAREFULLY ... it would show it was good when just sitting there.. but upon cranking with some vibration it would be intermittent and the car wouldn't start all the time.
Does ur fuel gage read accurately? I would pour in 5 gals of gas. It sounds to me like you may be out of gas.
Was it on the camshaft sensor cap side wiring connector or the harness connector that plugs into the sensor cap wiring connector?
