Squid4life said:Change the oil, pull the cam sensor out and prelube the oil pump and motor. Be sure to rotate the motor over (by hand) to make sure oil gets every where. Look in the breathers, or remove the valve covers to make sure oil gets to the top.
HTH,
Squid
Good question. Would this process be necessary for a gn that sat for 15 months?ksmmspt said:Hi,
I just rescued a wrecked 87 GN with the drivetrain intact. What steps should I take prior to trying to crank this engine. I know I have several hoses to replace. Thanks
justabuickv6 said:I hope not but I might be "in the same boat" as you are.
I live in Houston. The car is jacked up as high as I can get it in the garage.
I hope when I return that she is in good shape (no water damage) and that it won't be 6 years before I can start it again.
