Ron Tarabori
- May 25, 2001
153 cross bolt front and rear. 4.030 bore. The bottom of #3 is chunked from a rod and would need a sleeve. It is a very nice block. No other damage. Roller cam bearings, bronze lifter bores drilled for pushrod oiling and epoxied lifter galley. Has studs with 12 point nuts and washers. 4X casting on center. Cross bolt front main but not the rear. 3.905 bore, regular cam bearings, bronze lifter bores for .874 lifters. Block has been o ringed and has the starter corner cut off for chassis clearance. I can have it put back on (have done a few). Drilled between cylinders for cooling. Never blown up, no damage whatsoever. Nice block. Your choice $1200 each. Firm. 814 435 2939
