whitecobra98
- Dec 6, 2006
Have the dash taken apart pretty easy...can't get aluminum piece where speefo cable attaches to off old dash ...help!!!!!!!
That clip.will not budge.....any other ideas?
There is a spring clip behind the odometer/speedo head; just lift the spring tab up (towards the front of the car) and the assm. will separate from the cable collar.
Pretty easy.
On the digital dash, (not sure about analog) you have to unbolt the VSS optical (small 5 mm (IIRC) bolt) from the speedo head to get the cluster all the way out.
Sorry I said forward, when it is really back:redface: I don't know what would cause the spring to bind unless you pulled on the cable a lot and it's under load. Try pushing the speedo head in while pulling the spring clip back.
yup- you need to push the cable into the speedo (or the speedo into the cable...) to take the pressure of the clip.. then push the clip down and pull the cable away from the speedo (or speedo away from the cable...). sometimes it fights you, and only comes apart when it can sense that you are ready to push the car into the street and light it on fire..
