Autolite AR473turbobitt, what plug do you run?
I had/have the same problem. Lead coats the plugs and they short out. I found with the stock ignition that it gets harder to throw a spark through the gap and easier to travel through the lead coating.
I made 6 license passes in April and took the car home. Drained the 116 and drove it around a little with regular pump gas. A month and half later (Just a few weeks ago) tried making the a pass with 116 and misfired all the way down the track. Changed the plugs and problem went away.
AG.
That is a -10 heat range plug. Do you really need a plug that cold? Next time you pull one, look at the cad plating on the ground strap. It should change colors back to the bend. If it's not to the bend, it's too cold. If it's past the bend it's too hot. I'm running -8's.Is it normal to change spark plugs after six or seven passes? ngk 5820
