granitestategn
Gettin' there
- Jul 30, 2002
My car has the stock wastegate solenoid set-up. I'd like to keep it that way. I like the chip to be able to drop a pound or two in third. Stock adjustable wastegate actuator, too. I put a THDP on my car a few weeks ago. I'm having some issues at the track. I can't seem to control my boost. I'm not sure it's related only to the downpipe install. When I put it on I enlarged the turbo exhaust housing hole to 1" diameter and ported it to clean up the sharp edge. Now when I'm at the track I'm having a difficult time getting the boost level up in the low gears but it creeps in the higher gears. I couldn't get more than 15 PSI in the low gears but it was at 17 or 18 in third. It seems like I've got the actuator pretty short. I'm also shorting the TCC wire on the starting line so it locks when I hit second gear. Is locking the TCC this way aggravating my boost control problem? The car is getting KR in the middle of the run but it decays on the top end. My KR is about 4 deg at .780 mV. My peak EGT's were about 1550 deg F. When I shortened the rod, my EGT's rose slightly (a couple degrees is all) and the KR didn't get any worse. The boost didn't seem to change much. My car ran a 12.98 @ 103 a couple weeks ago but Friday night I had a string of 13.1's. Still had 103's all night. Couldn't 60' better than a 2.0 or I should have been in the high 12's again. I'm not looking for above 17 or 18 pounds boost with this chip. Do I need to lock the TCC later? Anybody else see this problem before? TIA!
