My 200-4R has been operating quite smoothly yet the shifts are not very firm. In fact at WOT I can't feel them. However, if I raise the RPM in gear and let off the gas, the shift is firmer. It almost seems as if I have to let off the gas to get a firm shift.
I am going to take a while trying to figure this one out.
I rebuilt the trans myself last year. I have a few hardened parts in there. Some Alto performance frictions. The pump is a 13 vane with a high pressure regulator. The VB is from CK with a shift kit, as is the governor.
I have a PTS deep pan and pick up. I also have a PTS wide band with a used GN servo.
The converter is a TCI 3000 stall something-or-other.
I have a hughs TV cable adapter on my Holley carb.
The beast is a 4000 lbs malibu with 3.42 gears and a 500HP/550TQ small block.
Static, the pressures seem to check out.
What are the next steps to finding the problem and then fixing it?
Finally, today I finally installed a TCC circuit. Wow, what a difference. However, with the pan off I noticed that the oil smelled a bit toasty. It was not pink anymore but was browning - not sure if this is related to insufficient cooling or running around with no TCC on or the few blasts that I did that flared.
Need help!
D.
Need help!
D.
