Selling out my spare engine stuff for hybrid
turbobob924
My wife is still sick and I dont have time to to put my hybrid back together after it has been in storage.
The medical bills are adding up....
Complete GN engine swap parts list.
Here is a start to see interest:
All prices before shipping
Precision TE44 turbo, good shape no end play. 350
Stock turbo in good shape 175
Casper's wire harness for GN engine swap, never used. 200
Stock wire harness including interior. 300 or 200 for just engine harness
Ported iron heads, 1.77 valves, cut for wire lock o-ring headgaskets, LT1 springs for flat tappet cam 500
Terry Houston DP elbow for tight fit engine swap or cut it to fit your project 150
Stock exhaust manifolds and cross over 100
Complete intake upper and lower with injector harness 150
Power logger 150
Motron 60lb injectors with less than 2 months use form Turbotweak 200
Inovative LC1 sensor and WB 175
TT SD2 chip for 60's and E85 150
RJC power plate 40
Coil pack, module and Magnacore wires, all worked great 125
Stock 109 short block with double roller timing chair and 206/206 flat tappet cam. Was running good before I stored it. I was going to put new bearings in it which I will throw in. 750
More to follow or PM me for other engine stuff if your are doing a hybrid or GN motor swap!
turbobob924
Interested in
do you have any pictures
Also some pictures of
What are the heads? Are they stock or aftermarket? Who did the porting? Miles on them or ever been run?
Here are 2 pictures of the intake upper and lower
I have the adjustable fuel pressure regulator and stock throttle body with aluminum plate for less vacuum lin pluming as well.
I dont know who did the porting and bigger vales in the stock heads. Pretty good port work though.
I got them a couple years ago when I lived in Chicago.
I do not have a complete stock TH down pipe. It is the elbow he used to sell to make your own fit. Im my case I used if to come over the valve cover and come straight down the back of the engine because of the tight clearances in my hybrid.
Here are 2 pictures
Again, not for stock use.
Power logger 150
RJC power plate 40
turbobob924
Pray for all the best with regards to your wife's health...
