Been educating myself on how to use scanmaster. Set tps to .42 off throttle and 4.2 at WOT. Here are my current block learn settings for each LV8. And knock and oxy info. I am happy with my air/fuel at WOT but getting knock in the top of 2nd and 3rd gear. Let me know what settings you think i should change and by how much. Thanks!
Current Scanmaster Settings (93 octane with lucas booster/21* TT Chip/42# injectors):
*Check signature for rest of mods
LV8 1 - BLM 142 Fuel WOT Overall
LV8 2 - BLM 140 Fuel WOT 1st gear
LV8 3 - BLM 120 Spark Timing 1st/2nd Gear (19.3 degrees)
LV8 4 - BLM 118 Spark Timing 3rd/4th Gear (18.7 degrees)
Knock Retard:
1st- 0 degrees
2nd (top of gear 4500rpm)- 4.3 degrees
3rd- (top of gear) 5.4 degrees
Oxy @ WOT (3rd gear pull)
750-764mv
Knock Retard:
1st- 0 degrees
750-764mv
