Are you trying to install a tach? If so, there is a factory lead behind the alternator that you can tap into for your tach signal. It's the green connector with two wires. Not the black connector with one wire, as that is the fuel pump test lead.
Typically on Autometer tachs, you will need to clip/cut the looped brown wire for V6 use.
-Patrick-
