Here's a question for you Jason. I'm certainly not an ignition expert here so pardon if this makes no sense. If you're not using the stock module and I assume the reason you are using two coil packs is so you can fire only the compression spark and let the waste terminal do nothing, is there a way to use the type II coil pack with it's 6 individual coils and somehow get the same results? I think the Type II can have the coils individually replaced so I assumed could be wired in such a way with your setup so that they are only fired for the compression spark and have a dead wire for the waste, maybe a resistor or something.
Again, I have no idea if this makes sense at all or if it's even possible.
Art.
