My experience is with a 14-bolt pan. You can probably get it out, but probably won't get it back in without raising the motor about 1/2" to 1" on one side.
1. Turn the crank to TDC on cylinder #1, to get the balance out of the way.
2. Remove the crossover pipe. This was my first adventure as a bolt snapped on the passenger side and I wound up having to remove the manifold to get it drilled and helicoiled.
3. On one side loosen the engine mount through-bolt, on the other side remove the through-bolt.
4. If you have a shop crane it's (presumably) easy to raise the motor with the stock lift bracket. At my own shade tree shop, we jacked on a front corner of the transmission, which did leave scratches. I now have a shop crane and would not choose to jack the tranny again, but it works.
5. With the engine raised far enough, re-insert the engine mount through-bolt you removed, so the mount rests on the bolt to keep that side of the motor raised.
6. Have at the oil pan. Clean the alarming metal silt out of the bottom.
7. The bolts on the rear main cap are torqued to 100 ft-lb. Dealing with them under a car on stands can be fun. With some difficulty I used a breaker bar and a long torque wrench. One curious note: I tried to use an impact style socket because that was the only 6-point I could find, but the walls were too thick to clear the cap casting around one of the bolts and barely cleared around the other.
8. The seal itself seemed easy. As they say, use the rubber set, not the rope.
9. Putting it back together is simply the reverse, unless you've left it up on stands for a month the way I did. Then you've probably drained your oil pump and need to prime it by pouring oil in through one of the oil cooler lines or, if you don't have the lines for some reason, taking the pump apart and packing it with Vaseline the old fashioned way.
--Jim Howard
