hello there Everyone
Don't mean to hijack the post, but mine does something similiar.....when the car is on and it gets warm, it begins to do some weird tap noises in the engine, the temp was checked at 175 deg to 182 deg..nornal, i took the belt off no noise??? it sounds like hard burps of water gushing through, it has a new water pump, thermostat with 2 drilled holes 2 help circulation, the sound was there before these changes so nope the holes in the thermostat not the problem, i know for sure its the water since when the engine is turned off the noises continue for about 10-15 seconds, if i release the radiator cap vent arm the noises stop asap!?? i already purged the coolant twice new radiator,also the engine with all passages purged, good passage of water, all hoses are new, ???? now heres a question is the water pump differnt from a regular engine to a turbo? maybe my old one was bad and this one is bad now or wrong one? help... the noise does sound terrible, the last thing i tried is this, i turned the car on got warm, i opened the radiator cap, manually accelerated the engine in order for it to circulate the water, i then held the acceleration as i filled the radiator with more coolant, closed the cap, and released the acceleration, noise decreased but it now sounds like marbles?????
