Racetronix Fuel sending unit with 430LPH pump and lines
Racetronix G7 fuel sending unit with 430LPH pump used for half a season last year
http://www.racetronix.biz/itemdesc.asp?ic=FPS-G7W416EAN&eq=&Tp=
$250 shipped
Front to back braided lines with Russell performance filter -8an feed -6 return and all fittings
$140 shipped
What fuel did you run through this pump? Do you have the racetronix wiring kit as well? Why the change? Are the lines teflon lined or straight braided rubber? Interested....
Pm's responded.
Lines are normal Russell braded lines not Teflon lined for E85. The pump is E85 compatible. We don't have many E85 sources in our area otherwise I would use it.
Reason for selling all of my stuff is I purchased an 87 Limited that I am doing the stock appearing with my engine setup.
Thanks Brandon.
