which is better I see this flat stamped deal on e-bay and I also see the tube style,which is better and why?thanks.
I dont mind welding,I can do that,even if I got the round I will weld them,just wondering if there was any input on the two.
Why buy Egay when you can buy from KirbanWhy weld in
Kevin
As to your questions:
We actually carry both....the tube style has been out for many many years and bolts in same principle you see in your basement if you look up at the ceiling cross braces.
the GNX style gets welded in. Its like the original GNX.... being welded I would say that one has the edge. In road feel probably no real difference. The trick is to also do the front braces and connecting brace underneath and the missing or left out body bushings.
The end result is like having a new car very tight...
denniskirban@yahoo.com
Thanks for the reply,but I just said I saw the flat ones on ebay as a reference.and I have been racing for a long time,welding is less prone to failure,and I have a mig,and a plasma cutter here,so I can do it myself.
I got my years ago during Kenne Bell days... I bolted my, but other members welded thiers; if I had a mig I would weld it also.
I was not trying to offend My response was more like why do you want to weld,if you sell the car you can always unbolt and no signs are left.I only bolt into my cars as it is easily turned backI see the ebay posts all the time,I try and buy from those that support me.You will NOT find better people to buy from than Kirbans:biggrin:
Kevin
