8. You tend to want to hug Julio at Alkycontrol. He won't like that...
IT'S A GREAT MOD ON A SERIOUS NOTE!!
Ethanol works just fine on a stock motor, no chance of mixing top fuel lube in it either as some methanol is sold that way that can kill certain pumps with certain plastic parts.
I use EFI pumps and actually add a capful of alky. lube each fill they like alky. lube.
DIY Northern hydrualic pump can last a long long time on ethanol with no lube added.
Ethanol costs about double what methanol alky. costs, sometimes triple if you get ethanol at Home Depot etc. I like 5 gallon pails from paint shops or furniture refinishing suppliers.
I'd get an ISAC alky. pump controller and a Northern pump for a stock motor.
The DIY stuff is easy to do too links and threads available with the search feature. :smile:
If you can't work on your own car, or install simple pipes, hoses, tanks, and nozzles, than buy a kit which is complete with good instructions it's only money.
Depends on who's doing the hugging
well this has become a fun topic now i suppose alky should be on the BUY list now. i will certainly add this wonderful item to the GN. now, should it be meth?
Good =is you can run lots of boost ,kill knock ,run 93 octane ,
Bad=Pump failure , keep filling Alky tank
Now Razor has a tester to make sure your pump is healthy, and you could also do the Metco spare tire fuel cell for 5 gallons of Alky . Guys will chime in here but thats the basics on it.
RAZOR aka Julio, PM him for see post above by Boost231
i do believe i will have to get alky. is julio the guy from alky control? do i call direct or pick it up from like g-body parts or somethin?
i tried to hug Julio once. i think he got wood.
That was the cucumber I had in my pocket
HILARIOUS!:biggrin: thats almost worthy of a poster lol
