626gn
- Feb 15, 2009
Cut and paste and attached a diagram for you...
Check valve is below the accumulator ball in the main body of the master cylinder
depressurize and remove accumulator ball
remove the steel line from the mastercylinder
there is a steel cartridge inside the opening , the check poppet is behind that cartridge with a spring behind the check poppet
to remove place a rag over the opening to catch parts and a quick shot of compressed air into the accumulator opening will push the parts out
clean the check face and the cartridge rubber face of sludge .
make sure spring isn't collapsed or broken
to install
install spring on check poppet , spring end goes into opening first
then the cartridge with rubber face in toward check
then reinstall hose
to install
then reinstall hose
