josh rosaaen
- Nov 29, 2012
I'm lost what does this mean is something not hooked up?There isn't one. Boost Analog input stays at zero.
The BLM also stays at 128, the O2 volts don't change and the ECM is seeing the P/N, 3rd and 4th gear switches all on. All the BLM's are locked at 128.
Make sure your wiring to the O2 sensor is correct. If so...replace the O2 sensor.Should I try replacing the O2 sensor or would a wide band setup be better
