Hi Everyone, wondering if my ignition problems could be from a weak alternator. When idiling my volt meter shows only 10 volts, when I give it some gas it will go to about 11/12 volts, but does not go higher. I am concerned that my ignition system is not getting enough voltage to spark at RPM's higher than RPM because the alternator is not putting out enough spark. Is this a possibility? I'm not sure how many amps the thing is putting out, but I don't remember it being a high one.
If it is the alternator, can any of you recommend a good one? I know I have heard of some people using Impala alternators, but I am looking for one that will bolt right in, but with more output.
Thanks,
Thanks,
