bradofflorida
- Dec 12, 2002
I am trying to choose between GN1 aluminum or ported stock heads(with matching intake), or just going with an SMC alky kit(progressive) and pumping up the boost. From my previous experience, I am inclined to go with the heads, as they are maintenance-free once in the car. I can also get more power with the same boost. Price is not a big consideration.
I have the following questions:
Will I have to upgrade the turbo to match the flow of the heads?
Will either of the heads hurt low-end power, thereby requiring a higher stall converter?
I would like to stay with the driveability of the stock convertor and power curve. I also may go with higher displacement when my original shortblock goes, either a TA aluminum block or a stage block if I can get one.
Current combo: 87 Turbo T, stock turbo, stock intercooler, unopened short block, XP pump, volt booster, FP regulator, Red Armstrong Chip, 160 degree thermostat, Iceman intake, hooker exhaust. Engine and tranny are tight.
Thanks for the help!
