It's not max lift that causes interference, it's duration. When the cam is at max lift (usually around 104-108 deg ATDC) the piston is some 2 inches down in the cylinder. If you have 2.0 inches of lift or so, then yes that would be a problem.
Ted,
If the heads are stock and untouched , the valve guide to retainer clearance should be checked. I would be more concerned with this if the heads are stock than with the valve to piston clearance.
