A fuel pressure gauge didn't come with my kit . Look at the second link I posted that is where the filter is mounted , Like Roc87 said , right near the old fuel filter location . SamRacetronix included a fp gauge with the kit. It looks like the gauge mounts on the passenger side feed. Is this correct?
Took me an hour to fish two nuts through there to back the bolts that were includedI just looked , drilled and tapped one , the other I could get a nut on it through the hole in the cross member .
Most likely need an adapter for the return line to fit the gauge. Like thisRacetronix included a fp gauge with the kit. It looks like the gauge mounts on the passenger side feed. Is this correct?
Which FP sending unit was it? I was thinking of grabbing this kit and their 416 single pump for a E85 conversion. Might end up going with Nick and his set up to include his new line kit coming out.
Wow ! Sorry to hear you had problems with your kit . Quality control must be going down hill . My Racetronix DP kit was perfect with no leaks on first try . Hope you get it squared away . SamOk, so got it all in. I have a massive leak on one of the so called "pressure tested fittings." Im so pissed! The 45 elbow from the tank right at the filter is leaking. It seems to be a bad seal where the elbow was installed onto the line. I suppose I will have to re-splice it.
The Racetronix hangers are wired for the pumps they sell, which is different from the more common Walbro and replacement pumps. I found this out after I installed their intermediary harness and my pump ran backwards.I believe it was the G7 SS Sender. Once I figured out that it was wired in reverse, I was able to take apart the connecter and swap the two power wires from the FP to the sender. I have a lot of practice dropping tanks now. I just installed a new stainless AN fit sender from Fullthrottle. It's real nice.
