Hello Forum Members,
After installing a new Walbro fuel pump from Full Throttle, Item Code: 834GMHP, and a Recetronix Hotwire kit, the boost is maxing out around 10.5 PSI (per dash gauge) and the car has trouble pulling beyond 4,000 rpm (per dash gauge) under WOT. The first start after installation was immediate and idles fine. Prior to this install the boost would run up to redline on the dash gauge.
I am looking for ideas on why the car is running sluggish and not building boost at highr rpm's. Were do I start?
Did I need a new fuel pressure regulator with the install of the Pump and Hot Wire kit?
The car is an 87' GN with 30,000 miles that I purchased last June. Prior to me, the car was completly stock down to the original air cleaner.
Prior to the Hot Wire Kit and Pump, the car was ran to empty the gas tank. However, I did also syphon out the last 5 gallons prior to the installs.
For directions, I used the postings from others here on the forums.
Since last summer, I have spent significant hours reading through all forums. Therefore, nn addition, 200 miles prior to the Pump and Hot Wire upgrades, I have also completed the "spring cleaning" that includes new:
8.5mm plug wires
AC Delco Plugs with .34 gap
K&N air filter in original air box
Fuel Filter
All fluids
Regards,
Matt
8.5mm plug wires
Fuel Filter
All fluids
Regards,
Matt
