Have a custom TA 62mm compressor with a "P" trim turbine wheel. Have two housings
a .63 garett cut for a "P" trim and a .82 T'netics . Motor is a .030 over 3.8 P&P heads, 210-215 hyd roller , 3000 stall 10" NLU 8.75 C/R Bottom end should be real strong with the Garrett but will run out of flow to soon on the top end. Which one would you try? I believe at one time Limit maybe have used larger compressor wheels with the "P" trim Garett labeled the LT45e ?
