10SECONDVSIX said:
I have noticed that on using a Direct Scan or a Scan Master the 02's drop in numbers at WOT with the 02 located in the stock location. Would it be beneficial to re-locate it at the lower part of the Down Pipe or the Test Pipe?
Is a Heated required for this change?
Just a thought.....
Joe
I think that for the "Relative" O2, your numbers will still "drop" whether you placed the O2 in the stock location or in the Downpipe.
Meaning that if (for example) the O2 numbers at the start of 3rd gear were a certain value and then lower as you went through the traps with the O2 sensor in the stock location, then if you were to put it in the downpipe, the O2 numbers at the start of 3rd, would be a certain value, but then will also be lower through the traps.
Now in absolute terms, some may say that putting the O2 sensor in the downpipe will give you an accurate reading. I cannot comment as I have never tried but I think others have and maybe can.
In theory, I would think that the O2 reading at the stock location vs the downpipe would be close to equal, this is assuming no leaks or problems causing the actual Air/Fuel ratio to skew as it travelled through the turbo exhaust housing. But other factors may account for the variance if there are any, such as mentioned above EGTs, leaks etc...
My opinion is that relative O2 is more important for tuning a car and not so much the absolute values. Meaning that some cars may run best with WOT O2's in the 800's where as other cars may like them in the 760's......most cars fall somewhere in between however.
So for your particular situation, the O2 drop may be caused by not enough fueling, boost creeping away slightly. Look for trends on Direct Scan to indicate where to look.
Most cars have O2's that drop off slightly as the car travels down the last half, especially in 3rd. But a sharp drop indicates something that should be looked at and addressed.
