UR50SLO
The Reaper
- Jun 12, 2001
I purchased a DFI (box looks like a stock gm ecm) and harness from Lonnie Diers. If you read this Lonnie maby you can help?
It was intended for Buick engine. I would like to use this unit on a TPI with twin turbos. (pull truck) low rpm torque puller.
What changes to the harness or do I need a adaptor to match up to the stock TPI harness? I'm not very experienced with the DFI at all. Thanks for any help.. ~Scott
